Awesome work again. :) This is MUCH better, But there is
2 more. :)
1)When pause is executed during tap cycle axis and spindle
stop nicely and are staying synced. But no movement nor
spindle restart happens when pressing pause again nor are
the Rew and For buttons available. If i start spindle
manually by keyboard shortcut or on screen button, tapping
cycle continues until cycle is finished. And if spindle is
manually rotated (with a piece of wood. :) ) Z and spindle
are still synced, if i continue to rotate spindle in
either CW or CCW direction and reach beginning or ending
of hole, the spindle will turn on again and finish tap
cycle for that hole. In a way this is nice but obviously
not safe unless spindle would remain off and wait for user
to turn on spindle or prompt user to turn on spindle again
to continue. And continuing would end cycle for that hole
and continue on to next hole.I for one like the synced
option, just wish it would leave spindle off.:) Or maybe
be able to use the Rew and For buttons?
I know we went over this before.Most industry controls
dont allow anything besides an ESTOP condition to
overdrive a tapping cycle, which i dont like. :)
2) If the Halt button is pressed during tap cycle (when
tap is in hole) axis and spindle come to a stop in a
synced manner.Testing again by manually rotating spindle,
they stay synced and if spindle is turned back on the tap
cycle will continue for that hole until cycle has
completed. Typical standard default would be when a Halt
is executed the spindle and axis stops immediately and
synced is lost.Which i think is what you would want as a
default for most users.
Thanks again,
Troy
